Electric problem >
Electric problem
Electric problem
Old 06-05-2018 | 08:24 PM
Default Electric problem
Ok I havr twin 454 mag mpi if I turn either ign switch on it powers up both engines ( ECM,fuel pump and mad ign but to start engines they will only stat with right and left ign switch. If I leave right battery switch on and shut left one off then the right key switch powers only the right motor and vise versa for left it I turn both battery switchs on then either switch powers up both engines batteries are seperated and ground and power cables go from each battery to there own engine please help thanks
Ty95 is offline
Old 06-06-2018 | 07:06 AM
How many batteries are on the boat?
Are you using an isolator or something else to charge more then one bat?
What is used to combine batteries when needed, a switch or relay?
How long have you had the boat?
AllDodge is offline
Old 06-06-2018 | 09:29 AM
One battery for each engine each engine charges it's own battery and they have seperate battery cut off switchs just got the boat in March of this year
Ty95 is offline
Old 06-06-2018 | 09:42 AM
I understand how one key can turn both motors ON, and not be able to start both, even though it shouldn't be able to do either.
The PO had something installed and when removing or rewiring something, there was something done.
Look at the Key switches and see if there is a jumper or other connection to the purple wire somewhere. With the key OFF, use an ohm meter and check between the purple wire on each key run terminal (purple wires). There should be no continuity between the two. If there is, start looking at wires behind the helm for a jumper between gauges
If there is only 1 voltmeter look for a switch that allows one motor to be looked at one time. If there are 2 voltmeters, see if they were swapped in some way in wiring.
I no isolator is installed, look for something that may have been installed before
AllDodge is offline
Old 06-06-2018 | 09:59 AM
F-2 Speedy's Avatar
maybe this diagram will assist you, each wiring harness should be isolated from the other one,
F-2 Speedy is offline
Old 06-06-2018 | 10:11 AM
I will look tonight do you think that would cause ign problems ran boat 2 days no problem end of second day lost both motors with in a 150 feet of each other no spark got it home did some probing both motors fired up and ran
Ty95 is offline
Old 06-06-2018 | 10:15 AM
Sure, there is something that was done and what ever it was, it should not have been done
AllDodge is offline
Old 06-06-2018 | 10:22 AM
Thank you I will be sure to post my findings
Ty95 is offline
Old 06-06-2018 | 10:28 AM
F-2 Speedy's Avatar
sounds like grounding issues,
Old 06-06-2018 | 10:33 AM
I think I am convinced it has something to do with the purple wire behind dash
Ty95 is offline
