Ignition shutting down when WOT. >
Old 06-09-2018 | 11:16 AM
Default Ignition shutting down when WOT.
This has happened a few times. When ruining wot for 30 seconds or more the boat just shuts down. . like all power is killed to the ignition. It sits for a minute or so then everything comes back to life. Seems like there is a breaker tripping and then automatically resetting. Are there Auto resetting Breakers somewhere? This is a MerCruiser originally had a 454 now as a 540.
tnc110 is offline
Old 06-09-2018 | 11:55 AM
F-2 Speedy's Avatar
what ignition, distributor, coil are you running
F-2 Speedy is offline
Old 06-09-2018 | 12:40 PM
mrv8outboard's Avatar
coolrunning racing
You could also be running it out of fuel. What is your set up?
mrv8outboard is offline
Old 06-09-2018 | 01:17 PM
Had a similar issue years back. Dist cap and rotor had some corrosion and under heavy load engine would just shut down.
It also could be coil or a distributor module that is heating up.
Griff is offline
Old 06-09-2018 | 03:59 PM
Daytona ignition. Not sure on coil.
tnc110 is offline
Old 06-09-2018 | 06:49 PM
I had a similar issue.. was clueless as to why!! While running, I lost rpms and fell on its face. Was still running when I stopped, I gave it throttle and it was fine. Did the same thing a few times. 454 mag mpi... btw.
I ended up finding a thread where Mark Boos mentioned it was the TPS.. that was it.. fixed it. Throttle position sensor. oh, I wasn’t WOT, but just throwing it out there.
nailit is offline
Old 06-09-2018 | 09:35 PM
BUP
A scan tool hooked up while running would have pin pointed right away --- TPS parameters.for your app ^^^^
for the OP it was never mentioned if this was a carb or MPI engine. IMO this is a carb app. More info is needed. Huge difference from carb to MPI engine for shut down issues.
to the OP - what does voltage show at shut down ? voltage on the gauge - voltage across sections of the engine with a volt meter - at the starter and at the alternator - what is voltage readings ??? Is the alternator going bad ???
Next test --- sealed inline spark checkers - do you have spark trying to recrank the engine ? you can even put a sealed spark checker inline for the coil to top of distrib cap - do you have spark ?
Next is it the fuel side - what is your fuel pressure at engine shut down and at trying to restart ?
3 tools here will find your issue(s) or at least where the problem lies.
BUP is offline
Old 06-10-2018 | 07:52 AM
when it happens you need to not turn off the key, open the hatch and see if the red status led is flashing fast.
indysupra is offline
Old 06-10-2018 | 08:02 AM
This is a carb engine. Voltage seems higher than it was before issue started. 15.5 volt if I remember correctly . After the first time it happened I replaced both batteries and the alternator and the problem is still present. It runs great no signs of missing or sputtering it just cuts out 100% when the issue occurs. It seems to me as though something is tripping and then resetting itself when given enough time.
tnc110 is offline
Old 06-10-2018 | 08:16 AM
I chased a problem like this some years ago..........it turned out to be the ignition switch of all things, would only do it at WOT go figure.
Camalot is offline
