Exhaust tips. Turned down
Old 06-13-2018 | 04:04 PM
Default Exhaust tips. Turned down
I saw fountain Express with exhaust tips turned down. They look like they are definitely under water with boat just idle.
I imagine this is to keep it quiet when off plane but wouldn't this be water reversion waiting to happen???.
veloc410 is offline
Old 06-14-2018 | 08:17 AM
Guessing they have internal flappers, also solid water actually helps with revision as it doesn't allow air to be pulled back in, acts like a damper of sort.
turbom700 is offline
Old 06-14-2018 | 09:17 AM
dcb
My 35 fountain lightning came with underwater exhaust, reversion not a problem as the tubes are submerged at idle and open when on plane.
dcb is offline
Old 06-14-2018 | 09:22 AM
My understanding is that reversion is more likely at idle.
thirdchildhood is offline
Old 06-14-2018 | 12:44 PM
Turn downs will not cause reversion.
Griff is offline
Old 06-15-2018 | 03:50 PM
Smile Inversion?
Well dammit turn them up!
sprsptr is offline
Old 06-19-2018 | 11:22 PM
so the water is harder to pull up the exhaust when submerged??? . It would be a great way to quite my rig down. I have longer cam 246 at .05 lift.
veloc410 is offline
Old 06-19-2018 | 11:24 PM
What if engine diesels
veloc410 is offline
