need to know where to buy a 1/2" fuel pickup tube >
Old 10-24-2002 | 01:06 AM
blue64drop
Default need to know where to buy a 1/2" fuel pickup tube
any ideas? i currently have a 3/8" pickup tube and aeromotive suggests minimum of 1/2" for their A1000 fuel pump
thanks.
Old 10-24-2002 | 06:30 AM
merlin540
we made one out of copper tubing and it works fine make sure the thread in your fuel tank will accept 1/2 tubing. you may have to modify that too
Old 10-24-2002 | 02:17 PM
Cignificant's Avatar
I had two fabricated for me last winter. Find someone near you - shouldn't be very expensive.
Cignificant is offline
Old 10-24-2002 | 08:01 PM
You can pick up a 10' length of 1/2" aluminum tubing at your local electrical supply house. If I remember correctly, when I converted my tank to 1/2" I welded a 12AN bung to the tank, then threaded the 1/2" pipe into 12AN to 10AN male adapter fitting. (you will have to thread the inside of the fitting) Then thread the fitting/pickup tube into the bung using an "O" ring. You can attach the 10AN fuel hose to the fitting. I do not know if this is the easiest approach but it has worked flawlessly for years.
Hope it helps - Dave
dckrafft is offline
Old 10-28-2002 | 08:55 PM
NEVRENUFF
Big thing is what size fitting do you have in your gas tank.
I had a 3/8th NPT female fitting into my tank. I custom made one out of 1/2" ID x 9/16" OD SST tubing. I got the tubing from Microgroup, Medway Mass. (you can find them on the internet) and welded the tubing to a SST 90 deg Street Elbow (3/8" MNPT x 1/2 NPTF). The 9/16 OD tubing fits snugly through the 3/8" female NPT. I then used #10 AN fittings to the aeromotive pump so I have a FULL 1/2 ID right to the pump.
I'd strongly recommend using the Aeromotive inlet screen filter and place the water separator/filter after the pump.
Good Luck
I think I had about $80.00 in parts for a pair of them by the time I was done
Billy Frenz
04-28-2008 04:03 PM
Leathl_WS6
9
12-06-2006 02:22 PM
duffster
1
06-15-2006 05:21 PM
red thunder
Prop Talk
9
03-16-2006 08:17 PM
Kanookstr
21
04-30-2003 10:35 AM
