Pair weiand 174 blower kits complete. >
Old 06-20-2018 | 01:29 PM
Default Pair weiand 174 blower kits complete.
I have a twin blower set up for bbc they can off of my formula 357. Converted two 420’s to 525sc’s. Both are complete with all pulleys and spacers for different water pump setups. Also included are two sets of pulleys 5lbs and 7 lbs of boost. Intakes are large oval but work with large rectangle ports as well. You can buy them complete with 1050 dominators or without.
With dominators...$4500 plus ride or $3500 without carbs. They are painted Merc blue and had them for three years. Both were pushing 5 lbs. when taken out of service. They should really have chillers and I can’t fit them under my deck that way so I’m building 540’s
instead...
offshoreratboy is offline
Old 06-25-2018 | 01:19 PM
Ttt
Old 06-25-2018 | 06:18 PM
Do you have pictures of manifolds and head surface? Thanks
Swamplizard is offline
Old 07-02-2018 | 12:04 PM
Default Pics
I have tried to post the pics that you asked for but my new samsung does not have copy and paist I have no other way accept email or text. You can text me first @ 440/5 free 7/ate sicks 23
thanks joe
Old 07-02-2018 | 02:05 PM
B38
Click on the paper clip in options bar.
B38 is offline
Old 07-02-2018 | 02:07 PM
B38
I believe you have weiand 177s. B&M made the 174
B38 is offline
Old 07-02-2018 | 10:06 PM
To B38. Weiand Made both a 174 and a 177. The 174 was designed for the SBC and used Holley square bore carbs. The 177 was designed for the BBC and used a Holley Dominator style carb. He is selling the 174's with an adapted to be able to use the Dominator carb. The other way to tell them apart is that the 174 has 4 long bolts to hold it down. The 177 has 6 bolts, 3 on each side, like the 8-71 style.
Good luck offshoreratbay on the sale.
gofastboater is offline
Old 07-03-2018 | 08:29 AM
TomFTM's Avatar
TomFTM is offline
Old 07-03-2018 | 08:31 AM
TomFTM's Avatar
Originally Posted by TomFTM
Are you sure.
TomFTM is offline
Old 07-08-2018 | 01:08 PM
Are you sure.
Yes he is correct they are 174s with replaceable rotor tips (TEFLON) any questions contact me via text...my new phone blows...440 five tree seven are 623
