HP transom assbly torque >
Old 06-22-2018 | 07:36 AM
Default HP transom assbly torque
Putting on3 on the Avanti this weekend, Dont remember what the torque spec is, though I seem to recall warnings of not using armstrong torque values..
Anybody have specifics?
phragle is offline
Old 06-22-2018 | 08:01 AM
Knot 4 Me's Avatar
I want to say it is in the 20 - 25 lb ft range. Someone will have the exact number.
Knot 4 Me is offline
Old 06-22-2018 | 08:42 AM
Shows 23 ft lb
AllDodge is offline
Old 06-22-2018 | 02:03 PM
I believe those are really sensitive to the torque pattern as well.
Baja Rooster is offline
Old 06-22-2018 | 05:57 PM
book #1 of service manual #39, page 2a-8, and i quote
tighten the transom assembly fasteners using an x pattern torque sequence starting from the middle fasteners.
tighten in small increments and go around the pattern several times until the proper torque is achieved.
so facing the inner transom plate; from left to right and from the top down, the x pattern toque sequence is,
5----7
3----2
1----4
8----6
i rechecked torque the next day to see if any squeezing of transom or stretching of bolts occured
there where no issues tho
outonsafari is offline
Old 06-22-2018 | 10:53 PM
BUP
the CORRECT info is 25 ft lbs for the nuts when installing the inner transom plate.
The torque pattern is very important. and torque very small increments using several passes with the torque wrench.
Using a X pattern starting from the middle fasteners and do so in small increments working up to 25 ft lbs.
going from top down for proper X pattern torque --- left to right ---- is correct above ----- starting with number 1 in lower left middle -- ( facing the nuts and studs.) starboard side ---
5 --- 7
3 --- 2
1 --- 4
8 --- 6
BUP is offline
Old 06-24-2018 | 02:58 PM
Got it all tightened down, and torqued to 25. No gaps and nothing cracked so I guess I did a decent job plugging the old cutout and cutting the new one. Now to figure out the front motor mounts. somebody needs to build an oso jig we can pass around instead of trying to drop a motor in align it as it hangs and contort yourself enough to drill the holes for the offshore mounts in the right place....
phragle is offline
Old 06-24-2018 | 04:25 PM
the plywood with the circles drawn on it was only to make sure the 496 front mount cleared the inner stringers.
easy to make for singles or twins. the engine slides on the cradle side to side real easy, front to back by prying w/ a 2x4.
just slid it around till it was aligned. threw it out 2 weeks ago
even with just the crank, bearings flywheel pan and coupler, the engine had to come out to drill some of the holes.
transfer punches worked where the drill couldn't get to to mark the locations
your going on the transom right ?
how about some pics of the rebuild !
Old 06-24-2018 | 05:13 PM
BUP
guess what there is one OEM builders use its called engine installation alignment jig --- special note I am not talking about engine alignment tool. - I am talking about the JIG.
BUP is offline
Old 06-24-2018 | 05:55 PM
BUP
read all about and has a pat on it
https://patents.google.com/patent/US4957462
BUP is offline
