H or P main & rod bearings >
Old 06-22-2018 | 02:04 PM
Default H or P main & rod bearings
Got my block back and the machinist's counter person gave me Clevite P mains and rod bearings ("because that's how they've done it for 50 years" type place).
I've read on here that H series are better with certain crank material and horse power ratings. This is going in a gen 5 -525SC rebuild should be about 600hp with a forged GM crank and Molnar 6.358 rods and JE flat tops, plan on running it around 4k to 5k with 5,600 to 5,800 RPM max.
What's better Clevite H series or P series for my application?
Mohavvalley is offline
Old 06-22-2018 | 02:20 PM
BBYSTWY's Avatar
The machine shop that just did all my work would not install P bearings in my motor as that's what I brought with it and frankly I didn't even look at them...I bought them from a performance shop along with all my other goodies and assumed they were right...NO!! lol they replaced them with H bearings....I hope I don't have this backwards but from what they said the P bearings are normal Passenger car bearings...The "H" bearings are High performance and like I said they would not assemble it with P bearings....for what its worth that's my experience lol
BBYSTWY is offline
Old 06-22-2018 | 02:48 PM
My machine shop said the P bearings are good for about ~500hp or a car that’s not wot for over ten seconds at a time. The upgrade seems like cheap insurance.
Baja Rooster is offline
Old 06-22-2018 | 03:50 PM
Mbam's Avatar
Offshoreonly Advertiser
100 years ago there weren't any H bearings. We made a fixture to cut the P bearings for the bigger fillet radius on our cranks and lived happily ever after. At the time is was 6000 and up to 800 HP.
So - I think if you have a crank with stock fillets the p will be fine.
Mbam is offline
Old 06-22-2018 | 04:59 PM
F-2 Speedy's Avatar
Dang I thought I was old..................^^^^^^^.......
F-2 Speedy is offline
Old 06-24-2018 | 09:55 AM
Really depends on the crank being used. H series are needed for most performance cranks with a radius on the journals. If the crank has no radius then a P or H will be fine. Clevite markets the H bearings as HP so with your setup I would errr that way.
Ryan00TJ is offline
Old 06-24-2018 | 09:01 PM
Full Force's Avatar
Bingo, all depends on the crank. the materials the same just the H have chamfer for crank filet
Full Force is offline
Old 06-24-2018 | 09:09 PM
i use p bearings for factory gm crankshafts all the time but if spending double for h bearings makes one feel better they also work well.the power output really does not come into ply.edit in,the materials are not the same,the p bearing is a little softer on the crankshaft side and has better ability to imbed dirt that is in the oil.
mike tkach is offline
Old 06-25-2018 | 09:43 AM
How can I tell what will work, do I need to measure the main & rods width and radius on the crank?
Mike, are the P bearings good to 800-850 HP?
Old 06-25-2018 | 10:37 PM
if you have a gm production engine crankshaft the p bearing will work no matter what the power output is,if you have an aftermarket crankshaft you need the h bearing.also note the h bearing offers about .0005 extra clearance over the p bearing.
