Mercruiser 500efi lifter replacement??? >
Old 06-23-2018 | 04:20 PM
Thumbs up Mercruiser 500efi lifter replacement???
I have to replace my lifters in my 500efi. Teague marine said crane cams 13532 will be direct replacement and is a bar style lifter. Also said will work with stock pushrod length. I am concerned they will not work with stock pushrods. Does anyone know if they will and does anyone have experience with these lifters. Thanks
RuninaFever is offline
Old 06-23-2018 | 11:07 PM
That’s what you want.
Add a -16 at the end and it’s the complete set.
tmmii is offline
Old 06-24-2018 | 09:19 AM
So the original pushrods will work with those lifters correct?
Old 06-24-2018 | 09:25 AM
yes. Are you also doing springs while it’s apart?
tmmii is offline
Old 06-24-2018 | 08:04 PM
Don't ask... yes... just did the heads, springs, valves, etc... 20hrs ago but didn't do lifters and a lifter just ***ged out on me and bent a valve so changing lifters now.
Old 01-27-2019 | 12:03 PM
I heard that the stock lifters were a odd length to begin with, something Mercury Racing did for some reason. Is it true you can actually get by with a standard BBC lifter and different size push rods for a lot less? If the case what lifters and what length pushrods? 850 for a set of lifters seems crazy to me.
s022mag is offline
Old 01-27-2019 | 12:11 PM
F-2 Speedy's Avatar
Aren't these the OEM dog bone style lifters
F-2 Speedy is offline
Old 01-27-2019 | 12:22 PM
Yes, least that is what was already in the motors.
s022mag is offline
Old 01-27-2019 | 12:33 PM
F-2 Speedy's Avatar
OP I have a brand new in the boxes 1 full set of OE lifters if you dont want to go tie-bar style, GM# 17120061
Old 01-27-2019 | 12:34 PM
Here is 1 of my projects
s022mag is offline
