need a picture of a HP500 EFI circuit breaker\ignition relay bracket
Ned,
Your hotmail account will not allow the file size that I tried to send I'll post a sample below. If it's what your looking for I'll try sending them again (smaller size)
I have Steps & Bubbles!
Scott, good pic but different from efi bracket but may work for him.
Ned, the efi bracket mounts to the rear of the port head and the mercathode mounts to the top with the solenoid and reset mounting vertical next to the end of the head. The harness connector mounts on the side directed to the port side. One bracket holds everything and is attached to the head with 3 bolts. Somewhere I have a pic of the rear of the motor showing the bracket, I will post it when I find it.
Todd
Todd
