12 volt wire source
thanks in advance
googled it a dozen ways and only come up with telephone twisted pair or wire from home depot.
anyone know a source for this wire, it's 16 gauge red-blue-green twisted up and in a nice jacket
for the power trim pump.
thanks
thanks
Probably just slid the wires through the jacket???
https://www.summitracing.com/search?...%20wire%20wrap
You can buy the 3 wire trim from ebasic power here
https://bpi.ebasicpower.com/search_2...q=wire+harness
but it doesn’t come in the cool old school yellow tracer loom. however buying this half wrap around nylon loom gives it a super clean look and easy to slide the wire into and isn’t 1980s corrugated plastic loom. In the link go down to the 3rd grouping and it says wrap around then it’s the first selection
https://www.mcmaster.com/#standard-c...eving/=1dk61dt
for 3 wire 16ga the 1/4” is perfect. You can squeeze it in 1/8 but you’ll be cussing. Also what you can do is route all your trim (2 tab and 1 drive pump) in a piece of 1/2” and as they branch off sleeve 1/4” into the 1/2 where the wires separate and a tie to hold them together.
really appreciate the fast responses,
closer inspection, it does look like the wires were slid in.
the picture is actually 2 separate looms for the tabs
the wires for the trim aren't wrapped and they are too short (pump moved)
branching off is a great idea,
can't thank either of you enough
