Go Back  Offshoreonly.com > Owners Forum > Sunsation
5 blade Hydromotive on 32 Dominator? >
Old 07-09-2018 | 09:10 PM
Default 5 blade Hydromotive on 32 Dominator?
My setup: 2003 Dominator with 500 EFI's, Whipple kits and making like 800hp per side. Drives are Bravo Shop Imco's with 1.36 gearing.
I had non labbed 30p 4 blade bravo 1's on the boat which were working well so far. Cruising at 3k RPM was 60 MPH and 4K RPM was 80 MPH cruising consistent for example.
Those props got taken out this weekend by some submerged crap, trying to find props, and maybe use this as a chance to try some new stuff this weekend also. A local guy has some very labbed/thin 31P 5 Blade hydromotives he said I could try on the boat.
Anybody ran a prop like that on a 32 Dominator in here and can share with me how that went?
SilverGhost is offline
Old 07-10-2018 | 10:46 AM
hey silver, I wish i had an answer for you but can you share the top gps speed and rpm with your 30's please? Doing similar power soon and was curious on my 30 pitch props. Thanks!
TracyRR is offline
Old 07-10-2018 | 12:16 PM
Knot 4 Me's Avatar
I don't think 5 blades on a non-stepped, pad bottom boat will work out great.
Knot 4 Me is offline
Old 07-10-2018 | 03:33 PM
also not needed..800hp, bravos and 5 blades will not be fun!
If that boat ran well with what you had I would go back to stock 30s or try stock 32s and lab from there - 4 blade
MINK is offline
Old 07-10-2018 | 04:50 PM
I found a set on the FB groups of 30p 4 blade like I had on there before, but the FS version. Similar enough to the stock ones I had on there that I think the boat will do fine, but curious to see how she does with smidge more aggressive prop in the FS version.
