Do Turndowns on STAGGERED engines FIT? Fountain 42 >
Old 07-15-2018 | 01:30 PM
Default Do Turndowns on STAGGERED engines FIT? Fountain 42
Do 4" Gibson Powercurve turndowns fit on STAGGERED engine setups?
2007 42' Fountain with 700sci's/SSM6 drives, 4" exhaust pipes, got ticket for noise in Wisconsin on Lake Michigan.
Wisconsin require 86db at 36" from exhaust at idle. Gibson claims <88db and on plane hopefully no loss in HP/MPH.
BUT: Measured for this and the CENTER 4" exhaust pipe (between the 2 SSM6 drives) space is too narrow with the plastic covers over drives right off transom; with the plastic covers off it MIGHT fit but not sure, will be CLOSE and with turning drives may interfere.
Starboardmost pipe is all alone and fits fine.
Port has 2 pipes to left of lefthand drive and should hopefully fit, maybe angled a bit away from drive.
That MIDDLE pipe between the drives will be the issue!
Has anyone done downturns on Fountain staggered engine setup, and advice?
xwing is offline
Old 07-15-2018 | 11:30 PM
You have an old thru prop merc exhaust elbow? Stick a merc boot or piece of 4 inch hose on the exhaust outlet and clamp the elbow on. Then see what you have for clearance and what adjusting you have to do.
dereknkathy is offline
Old 07-16-2018 | 08:14 AM
WOW! You got popped out on Lake Michigan?! I thought the LEOs left you alone concerning noise out in the big lake.
SS496 is offline
Old 07-16-2018 | 02:37 PM
Look into GGB inserts. They slide inside of pipe and don't affect hp.
underpsi68 is offline
Old 07-16-2018 | 04:19 PM
I have Gibson downturns on my 42 with 700SCis and staggered #6 drives and they work great. They will fit but the two on the port side need to be angled a little outwards to clear the plastic transom assembly cover. No issues with the center one, it clears just fine. I also run on Lake Michigan and haven't had an issue since I installed them.
GF?
Got Freedom? is offline
Old 07-16-2018 | 04:45 PM
Got Freedom: ok thanks for specific experience on same boat, will have to see how that center one fits because with covers on there just isn't 4" of space! Got to try and/or MAKE it work though...
Thanks for the other peoples' answers and info/help as well!
xwing is offline
Old 07-17-2020 | 04:56 PM
Any concerns with reversion?
TomR is offline
