Porous Gelcoat
Old 07-17-2018 | 03:38 PM
Default Porous Gelcoat
Hello All,
I currently own a 28 ft Pantera and boat in the Chesapeake Bay by Baltimore Maryland. It was built in 2000 and the gel coat still shines. My issue is that the bottom of my boat turns dark brown if it stays in the water over a weekend (picture below). To remove the brown, I am forced to use starbrit hull cleaner. I would like to be able to boat for a weekend and remove the brown with a simple wash. My question is, what are my options to achieve this goal? If this did not make sense, please let me know and I will try to explain further.
MMatt28 is offline
Old 07-17-2018 | 06:56 PM
Hey I also boat in the Baltimore area. Patapsco, Middle river mostly. My 97 Sonic looks like your too. This is an easy cleaning solution to use in a garden sprayer. Buy some “Works” toilet bowl cleaner in the green bottle, only $1 each. Put in garden sprayer with a squirt of Dawn dishwashing liquid and spray on stains. Hull will be white again instantly. Hose off with hard spray from water hose. I wet my trailer down well before to prevent any reactions from the cleaner. The dishwashing soap is in there to help the solution stick to the hull and reduce dripping on the trailer. The “Works” is a mild acid so caution should be used. Try it.
sonicss42 is offline
Old 07-17-2018 | 07:51 PM
ROB FREEMAN's Avatar
my boy used that crap on his ski boat . year later the gel coat is more pouras than ever . he swears that stuff made the problem ten times is bad ,, I told him to try that secret from pervious threads here . I wont use it on my hull . for that reason 2005 ski centurian ..
ROB FREEMAN is offline
Old 07-18-2018 | 08:13 AM
ben
Ceramic coating, or wax it every other time you go out. Getting it ceramic coated saves a lot of time waxing.
ben is offline
Old 07-18-2018 | 11:34 AM
Use Bar Keepers Friend - it won't hurt the gel and spray it on - lightly rub with sponge and hose it off
MooresWarlock is offline
Old 07-18-2018 | 01:01 PM
There is really not anything simple that you can do. Wet sand, buff and wax the bottom will help. The other option, if the boat is only left in the water for a few days at a time is to have the bottom painted.
Griff is offline
Old 07-18-2018 | 05:15 PM
I wanted to try that but it was only guaranteed for one year below the waterline. Pretty expensive yearly treatment. How long has yours lasted?
NightHawk is offline
Old 07-18-2018 | 09:00 PM
Interesting, I will keep an eye out for this as I have only used my Works blend a couple of times. Thanks
Old 07-19-2018 | 08:41 AM
As griff said. Wet sand and buff it out. Little work but not that bad. Or just shoot the bottom of the boat. Since not in water all the time.
Old 07-19-2018 | 09:42 AM
ben
I just had mine done early spring so no long term results yet.
ben is offline
