Mabey I’m learning,,
Old 07-22-2018 | 09:06 PM
Default Mabey I’m learning,,
Ok, I’ve been reading some more, if you lock your timing on a blower enigne, will it help with rotor phasing?the previous owner melted the top post of the coil,3 holes burned all the way through. Could this be caused by improper rotor phasing? I’m totally new to super charging, and will probley only get one shot at this befor my project boat turns into a parts boat.I have two msd- 7ml-2 ingitions, one has a couple burned resistors. ( the one that melted the coil)
Scscoripion is offline
Old 07-22-2018 | 09:30 PM
SB
rotor phasing is not changed with timing changes, locked or not,
Phasing is the relationship of the rotor under the cap posts. ust type in rotor phasing into your search engine and read away.
Why do you have 7 series ignitions ? Although not limited too, most are only used for short duration racing events like drag racing and top speed runs. A typical blower motor used in a boat does not need a welder as an ignition system.
What do you have for a motor set up ?
SB is offline
Old 07-22-2018 | 10:59 PM
That’s the ingition that was in the boat when I got it as a project boat. I was thinking after looking at that 7-al2, it was not right for the boat(39’chris craft scoripion). So, I need to buy two 6m-2l ? the previous owner had this boat set up very bad,from everything I’m seeing.plug wires all zip tied in one bunch,3/8 fuel supply,small water/ fuel separators,etc,etc. I’m sure hoping to get it set up right,have new fuel systems,160 gph,all 1/2”, trying to get the ingition’s figured out now.
Old 07-22-2018 | 11:10 PM
454-.060 over,8.6 to 1,stainless marine headers, b&m250,s holly marine 850’s boost referenced , msd marine distributor’s , aluminum pistons, ( engen,s started life as merc 400’s)
Old 07-22-2018 | 11:11 PM
Also, 24 pitch cleaver props, 4 blade.
Old 07-23-2018 | 04:50 AM
We also installed innovate afr gauges,Im going to have to extend the port sensor wire , bought the 18’ wire, to short, but with the 5’ wire that came with the gauges I’m hoping it will be long enough.
Old 07-23-2018 | 04:29 PM
Swap to Daytona ignitions. Locked timing isn’t a great thing. Yes it’s been done for years and engines have melted done for as long. A better tunable ignition is far superior to locked timing. I just installed the Daytona’s on my NA motors. Engines were dropping 450+ rpm going into gear. Now with idle stabilization it’s only a 200 rpm drop or so.
Crude Intentions is offline
Old 07-23-2018 | 08:07 PM
Yeah, the Daytona Sensors Ignitions are the schitz. I want one.
NHGuy is offline
Old 07-23-2018 | 08:30 PM
Just looked at the Daytona ingition, at 600 each why not go with safeguard? Would it be better to have knock control? I’m totally new to these sc motors, I really miss my n/a 502’s in my 40’ Excalibur! Ran perfect with hei’s , still had vacume advance! Would turn 6000 rpm very easy, 21 pitch 3 blade marage’s. What if I got a pair of 65000volt hei’s , removed the vacume advance, set them to fully advance by say 2800? Like I said ,I’m open for suggestions, never done sc befor.
Old 07-23-2018 | 09:18 PM
  1. <div style="text-align:left;"><img src="https://cimg0.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/1334x750/80548315_38c0_486b_824c_2a4f48ae7690_10a522ba3e813 74de8e3a8aee2d7103ef8fc4696.png"/><img src="https://cimg3.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1504/06cf51bb_a524_435f_ae02_eae83deff82a_43867ed6e56ce 2c1ab7392ad1c58e3fcfa80bd77.jpeg"/></div>
