Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
rebuilding bench seat plywood. what to seal with?? >
Old 07-24-2018 | 06:13 AM
Default rebuilding bench seat plywood. what to seal with??
Im rebuilding my bench seat & side panels with construction plywood then having them reupholstered. My question is what the best way to seal the wood? some info i got was to use anything oil based. is this all i should do? would behr oil based enamel work from home depot? Also thinking of this product BEHR PREMIUM Transparent Penetrating Oil Wood Finish
any tip appreciated thanks.
apex808 is offline
Old 07-24-2018 | 07:57 AM
cougarman's Avatar
Put 2 coats of fiberglass resin on it, first coat will soak in pretty good, second coat builds nice. Can do a 3rd if you wish.
If you can seal ends, end joints before assembly added bonus.
Jon
cougarman is offline
Old 07-24-2018 | 08:34 AM
convincor's Avatar
I do what cougarman says
convincor is offline
Old 07-24-2018 | 06:39 PM
the Behr is a finish, not a sealant. the oil based enamel is a finish, not a sealant. Some may say this is splitting hairs...but what they said...if you want it to last.
Pete35Fountain is offline
Old 07-24-2018 | 08:01 PM
rak rua's Avatar
Many years ago, i made an ice box for the cabin of a sports boat. Used the same method, glass resin over plywood then painted and it worked fine. Inside and outside sealed nicely, pretty easy and dirt cheap.
RR
rak rua is offline
Old 07-25-2018 | 07:56 AM
What kind of resin? epoxy? or can i just use cheaper stuff like polyester? thx
apex808 is offline
Old 07-25-2018 | 08:05 AM
convincor's Avatar
I use polyester laminating resin. (no wax)
index.html
I've also gone back over it with gelcoat on the inside to give it a finished look.
Outside covered with vinyl.
File Type: html
Old 07-25-2018 | 09:48 AM
I dont have that available what about pro form resin PRO FORM - Products they have it available at my local car/body paint supply shop. or bondo by 3m?
apex808 is offline
Old 07-25-2018 | 10:03 AM
convincor's Avatar
Problem with that is it has wax. So the second coat won't stick to the first.
Old 07-25-2018 | 10:04 AM
convincor's Avatar
Amazon Amazon
