Baja 275 Boss - 496 Mag HO Correct Prop >
Old 07-25-2018 | 06:32 AM
Default Baja 275 Boss - 496 Mag HO Correct Prop
New to this Boat/Forum,. Can you guys recommend the right prop (make /pitch) for this boat. Primarily for top end without bumping the rev limiter, Thanks
woldt1 is offline
Old 07-25-2018 | 07:46 AM
I've got the same boat. Running a mirage 23P. Runs mid 60s on GPS.
jbowling is offline
Old 07-25-2018 | 08:34 AM
Thanks!!
is your prop lab finished? is it worth it to get it done?
woldt1 is offline
Old 07-25-2018 | 08:45 AM
No, mine isn't finished. I've heard you can pick up a mph or two maybe with a labbed prop. I ran 65 gps on it a week or two ago with 2/3 tank of gas and 2 people in the boat. Maybe if all conditions were perfect, light fuel, blah blah you could hit 70 with a labbed prop, but it's not worth it to me just for bragging rights.
jbowling is offline
Old 07-30-2018 | 12:13 AM
Same boat.. Same prop 62mph GPS with fumes and two people and two lifejackets on board, fairly smooth water. Took forever getting out of the hole. Got a REV 4 21P and love it, 59mph top speed with a couple hundred pounds of gear, full fuel, full cooler and 2 adults, and it gets right to the 58. JUMPS out of the hole. BBLADES recommended this in place of the Bravo1 labbed prop for me as I didn't want to wait a couple months for the new prop.
Robi523 is offline
