shipping props???
Old 10-25-2002 | 07:47 AM
dyno's Avatar
Charter Member #655
Default shipping props???
I need some cheap boxes to ship my props any idea's....?
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 10-25-2002 | 07:50 AM
CRUBOSS
try some plywood and screws. this is a fool proof way to ship props without damage. unless you have some merc. prop boxes. u p s has damaged alot of props that were not packaged correctly. if they are worth the money , protect them.
Old 10-25-2002 | 07:53 AM
throttleup's Avatar
Default Shipping Props
There are a few boxes I recommend to ship props in. As we know shipping can be brutal for props but there are a few boxes on the market today specifically designed to withstand the woes of shipping. What type of props are you shipping (Diameter is important for selecting the proper cases) I carry prop cases for this purpose. What is the price range you would like to stay within? Hope I can help.
Throttle Up Propellers
www.throttle-up.com
877-842-6855
throttleup is offline
Old 10-25-2002 | 08:03 AM
Zanie's Avatar
I worked a for UPS for 6 years. You don't want to know what happens (on occasion) in the sorting hubs.
Pack them to withstand a 4 foot drop AT LEAST.
OVER insure them.
You might try strapping the prop into a plastic milk crate and putting that in a box.
On the brighter note, last summer UPS delivered my Bravo 1s in the Merc boxes from MI to IL in excellent condition.
Zanie is offline
Old 10-25-2002 | 08:17 AM
Luv-N-It's Avatar
Are there any new home construction sites around? I just had my prop labbed. Went down the street to a dumpster, found a decent size box, filled it with newspaper (alot) in the bottom, around, and on the top of the prop, dropped it 1 ft, 2 ft, never heard a sound. Taped up good and sent it. Was sent back to me without any problems the same way I sent it.
Do it this way, you'll be fine.
Luv-N-It is offline
Old 10-25-2002 | 08:20 AM
traviss's Avatar
Yeah us UPS guys do drop them at least 4 ft package them good boys..
i had seen a high doller set of heads fall off our catwalk, broke the wood box and screwed them up bad..
traviss is offline
Old 06-08-2003 | 04:22 PM
lucy's Avatar
try these!!!!!!!!!!!!
lucy is offline
Old 06-08-2003 | 04:25 PM
lucy's Avatar
call julie at throttle up 877 842-6855
lucy is offline
Old 06-08-2003 | 04:51 PM
Mr Gadgets's Avatar
Charter Member #601
Dyno,
I have shipped props before with regular prop boxes, cardboard with a few extra layers top and bottom with a hole bored in them that the hub sits in.. That seems to work pretty good. Another idea is to take a piece of plywood the size of the box and bolt the prop to it. I would add the cardboard on the top for a stabilizer for when Travis see's it coming down the line. And do insure it for a million.. Good luck
Dick
Mr Gadgets is offline
barron
08-23-2006 01:53 PM
jmackin
03-04-2004 11:12 PM
2112
02-10-2004 12:16 AM
WES311SR1
01-10-2002 11:14 PM
