New fountain owner 97 35 lightning. New 502 with carbs. >
Old 07-31-2018 | 08:40 PM
Default New fountain owner 97 35 lightning. New 502 with carbs.
Need advice on props to use to get best performance. I have 1:5 ratio. What should my top mid and top speed.
drsparksnynj@gmail.com is offline
Old 07-31-2018 | 09:10 PM
Good question. I have a 35 also. I upgraded my motors to 650hp at crank. I run a set of merc 30p labbed props. I believe you should have merc 28s. My cruise speed at 3100rpm is 50mp wot is about 86mph depending on fuel load and wife as a speed limiter. If I put the 28p back on my rpm wot is the same. Rpm is the same and my cruise speed at 50 mph is at 3600rpm. I don't want to think about this issue anymore. It drives me crazy
Drew555 is offline
Old 07-31-2018 | 10:08 PM
The old owner has signature 28P on it now. He said it runs 55 mid and 72 top end. It's a new stock motor. He also has a set of bravo 28P and a set of hydro which I'm not sure of the pitch. He said the hydo will increase my speed a little.
Old 08-01-2018 | 05:22 AM
I have a 95 35. Spinning 27 hydros currently. 60@4100 cruise. My motors made 570 in full marine trim through wet exhaust. However the 27s were what came with the boat with stock 502 mags. Boat loves them. QIVs. I haven’t begun all the wot prop testing yet as I’ve had a couple bugs to chase. I would see what those hydros are and do for you.
Crude Intentions is offline
