Parts parts and more parts >
Old 08-01-2018 | 03:26 PM
Default Parts parts and more parts
502 upper Intake manifold and a throttle bodies X 2, (not fresh water, need to be cleaned up) $200 each intake, $100 each throttle body
496 Cool Fuel $400
Formula table and stand $40
Mercruiser 420 HP Intake with Holley carbs and HP spark arrestor and cap $400
Mercruiser 420 HP Intake -w/ a small crack at manifold fitting, with Holley carbs and HP spark arrestor and cap $325 (I can send crack pic). $675 for both.
Mercruiser 420 MP Valve Covers $100 per set.
Thunderbolt ignition modules from 420HP 454s $100
496 Cool Fuel $400
Distributor $90
Kiekafer trim tabs for parts or repair. $390
Guest switches $10 each
502 MPI cool fuel hoses un tested used $40 for all
502 MPI Cooler hose $15
2000 Scarab AVS 33 engine room Diamon plate panels $300 you ship or pick up
502 MPI raw water pump and pulley front, needs bearing $20
Teague sea strainers very nice(new glass and seals) can send more pics $150 each.
Set of Gil manifolds $500
420 HP Mercuiser Racing 454 needs rebuild $1200
Mando Alternator (untested) $40
Water flush fittings $40 for both
BLue sea distribution panel NEW $50
All plus ride.
cyrus77 is offline
Old 08-01-2018 | 05:06 PM
Sick Stinger's Avatar
Brotherhood #1
Take 150 for the ign modules?
Sick Stinger is offline
Old 08-01-2018 | 05:30 PM
old bird's Avatar
I'll take the water flush fittings .
and the red Guess switch.
old bird is offline
Old 08-01-2018 | 05:47 PM
Pm sent on strainers
Mohavvalley is offline
Old 08-02-2018 | 06:59 AM
What are the studs/bolts in the ziploc bag for? I need a set for a Bravo transom.
floatingphil is offline
Old 08-02-2018 | 09:24 AM
Pm sent
Mike S. is offline
Old 08-02-2018 | 11:14 AM
I'll take the strainers if they have not sold yet... Juan 817-808-6068
jamontes is offline
Old 08-02-2018 | 07:20 PM
Strainers sold to me, money sent.
Thanks Cyrus
Old 08-02-2018 | 08:14 PM
Thanks man for posting! You got a good deal.
jamontes is offline
Old 08-03-2018 | 02:42 AM
Default just test post, delete me 113840940
just test post, delete me 818547215
AbakbakoSal is offline
