Winterizing Oil Change Question >
Old 08-05-2018 | 01:02 PM
Default Winterizing Oil Change Question
Why does the oil get changed at the end of boating season and not at the beginning of the season?
GLENAMY 242SS is offline
Old 08-05-2018 | 01:23 PM
Rookie's Avatar
Oil has gas, moisture, dirt and contamination in it. It's just good to clean the engine internally before winter layup.
With that said I have never done it. Always plan on it,
Rookie is offline
Old 08-05-2018 | 02:30 PM
BUP
All marine manus strongly say this about all oils to be changed at lay up time including the outdrive oil. The reasons are New oil is not contaminated in which offer better lubricity and offers better corrosion protection.
Oils that have run time and over that time --- plus the heating and cooling of oils cause it to oxidize along with moisture build up. This alone breaks down the additives within the oils itself. Also with used oils they form acids along with oxidation process ---- this over time can be hard on bearings and especially seals. A short jist of an answer.
BUP is offline
Old 08-05-2018 | 02:40 PM
Bup, thanks for the response. I was thinking along those lines but wanted confirmation.
Another question, can I change before my last outing and should the engine be run to circulate the new oil before layup?
Old 08-05-2018 | 05:05 PM
BUP
you need to run engine and drives on water hose and for winterizations or the lay up process anyways. Change your oils first - then lastly run engines and drives on water hose with fuel lay up mix as well. The new oil changes coat all parts for better protection plus you want to run your fuel side lay up / 2 stroke oil fogging mix thru the engines. Wise to bring the engines up to proper temp and run for a good 5 to 15 mins after that.
BUP is offline
Old 08-06-2018 | 07:15 AM
mrv8outboard's Avatar
coolrunning racing
The other thing is that the hydrocarbons build up and the oil goes acidic not base causing acid etching of the bearings.
mrv8outboard is offline
