Runs Hot In Quiet Mode >
Old 08-07-2018 | 05:58 AM
markt111's Avatar
Default Runs Hot In Quiet Mode
I have an older boat, it has a 1992 502 carbed with Corsa Quick and Quiet, the boat has been running warm lately when I switch to quiet mode, the boat runs 150 with the thru hull open climbs to 170-180 thru the drive. Is there anything in particular I should look at? The engine has under 500 hours and runs great...
markt111 is offline
Old 08-07-2018 | 05:59 AM
markt111's Avatar
I should mention the lake I run in is over 80 degrees currently
markt111 is offline
Old 08-07-2018 | 06:40 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
What RPMs do you run at with the exhaust switched to quiet? You are not supposed to run over 3000RPM with any of those systems in closed/quiet mode.
Sydwayz is offline
Old 08-07-2018 | 08:18 AM
markt111's Avatar
probably slightly over, 3200-3400 easy cruise speed. Anytime I run hard I open up,
markt111 is offline
