Vortech Superchargers
Selling a pair of Vortech Superchargers model# V-4J. They were on 500 EFI's and are approximately 10yrs old with approximately 250hrs. Running 4psi of boost. Was told the motors made just over 700hp. I can not confirm this tho. Boat they were on is 2000 35 Cigarette Top LE (Straight Hull) and was told it ran 88-90mph. I bought the boat in the spring with them on and took them off because I just did not want them ( I know, Im crazy, been told that many times). These are the open oiling system, so they were set up to tap into the engine oiling system. This should be a full bolt on set up for somebody with 500 EFI's as I took everything off. I was able use to some of the bolts for the stock brackets, so some bolts may need to be purchased to complete... Everything else I took off tho.
Superchargers, Chillers, Blow off Valves, brackets/ hardware/pulleys, oil lines, water lines, extra belts, are all included in sale.... basically everything you see in the pics are included.
*Fuel pumps and Injectors may have to be upgraded*
Asking $10,000
Curt
[email protected]
Any questions, please feel free to contact me via email or 8six2four3two8five0two
Asking $10,000
Curt
[email protected]
Not to nit pick, at 4psi you would be around 590-610hp depending on how Merc rated it. Just Dyno'd my procharger motor and I made 460/615 (NA/SC) at about 6psi and the blower took about 30 hp to do it. Just so someone doesn't get unrealistic expectations. Real nice setup though. Good luck!
Got Cigs, good luck with the sale.
