How do you take the salt off the prop? >
Old 08-08-2018 | 06:35 PM
jeff32's Avatar
Default How do you take the salt off the prop?
can t believe the crap that is stuck to my prop after only 5 days!!!
and not easy to wash and clean it back to original!
what are the right ways to do it?
jeff32 is offline
Old 08-08-2018 | 06:44 PM
I soaked mine in water and white vinagar. Came out looking almost new.
Baja Rooster is offline
Old 08-08-2018 | 07:18 PM
If that one on the right is a 24p, it’s toast- you just send it to me and buy a new one.... If not- Salt Away, lemon juice, vinegar, or any mild acid should take it off.
Speedracer29 is offline
Old 08-08-2018 | 07:38 PM
DM
I like the above suggestions and would try that first. Have had the same issue. Get the Scotch Brite brand scratch free "Dobie" sponge at the grocery store. Put some Mary Kate hull and bottom cleaner on it. Doesn't take much, as it has acid in it. It will rub off without much effort and keep rinsing with water. They will look like you are used to.
DM is offline
Old 08-08-2018 | 08:08 PM
rak rua's Avatar
Unless they've been labbed and tuned to extract 1mph more, I'd use fine steel wool and soapy water. I've been doing that for years and if it scratched them, the scratches were too small for my eye. Bravo's are pretty hard to hurt.
RR
P.S. I know your question was asking the "right way" to clean them so my answer is probably the wrong way but it works for me.
rak rua is offline
Old 08-08-2018 | 08:18 PM
Try any mineral/lime remover like lime a way or Zep tile and tub cleaner.
kjm5125 is offline
Old 08-08-2018 | 10:45 PM
Snobowl toilet cleaner works great
obrien is offline
Old 08-09-2018 | 01:16 AM
^^what he said.
apex svt is offline
Old 08-09-2018 | 02:04 AM
jeff32's Avatar
Thanks for all your replies! Will try that tomorrow!
jeff32 is offline
Old 08-09-2018 | 06:10 AM
SLOWOUTBOARD's Avatar
if you use steel wool ,use 0000 size ,works on chrome without scratching it.
SLOWOUTBOARD is offline
