Trim pump problem doesnt go up or down but trailer works
I finally got the engine back together and took it to the lake. I couldn't get the drive to lower so I didn't go out for a test. The trailer button works but not the up down switch. Something tells me I forgot to hook something back up maybe to the trim sender. Is there a connection through the hull somewhere? It was working prior to rebuild. I took the 20 amp fuse out but it broke so I don't know if I broke it or it was already broken. Either way would that allow the trailer button to work but not the up down switch?
