Where is the best place to read about MEFIBURN? >
Old 09-01-2018 | 03:19 PM
Default Where is the best place to read about MEFIBURN?
Can find much info on it.
cyrus77 is offline
Old 09-01-2018 | 05:13 PM
What is it you want to know?
MEFI Burn itself is merely a handshake and transfer protocol between your computer and the MEFI ECM. It will transfer the .bin file from the ECM to your computer and write a new .bin file to the ECM.
Scanner Pro will read the data stream output and log the parameters on your computer.
TunerPro is used to actually change the internal file settings, like BPW, advance, etc.
Three sets of software.
Trash is offline
Old 09-01-2018 | 09:11 PM
Do some research on Tunerpro. It is the actual "tuning software" that you will be using to modify the parameters you need to change in the MEFI.
Paxtonspeed is offline
