Herring 5-Blades vs. Merc Props? >
Old 10-26-2002 | 05:48 PM
O-Limit37
Default Herring 5-Blades vs. Merc Props?
I'm looking for some input on Herring 5-Blade cleavers. Has anyone made a switch to them from Merc Props? Any noticeable difference in speed or handling? Currently spinning labbed 32's @~5400 rpm's on XR drives on a 37' with 650's.
Thanks.
Old 10-26-2002 | 07:53 PM
Bosco's Avatar
Great prop's, they actually work too well. The bravo drive pushing a heavy load hooks up like tires on asphalt. Problem lies in the vertical and prop shafts not being able to keep up. Anybody else snapped a shaft ?
Bosco is offline
Old 10-26-2002 | 08:33 PM
timucin's Avatar
why dont you friends use ROLLA props?
it is known as the best prop in Europe
timucin is offline
Old 10-28-2002 | 10:59 AM
throttleup's Avatar
Default Props
The Herrings are great props. Increased acceleration and bite are can be expected. However with these increases, it is also recommended that they be used on XR/XZ or B-Max Drives. It is not uncommon to see slight decreases in top end with these props.
throttleup is offline
HiPerf2000
Prop Talk
1
08-01-2007 01:08 PM
WildWarrior
Prop Talk
0
09-18-2006 05:03 PM
Popeyes
10-26-2005 05:10 PM
two-air
0
05-13-2004 06:51 PM
Von Bongo
Pantera
1
11-01-2002 12:49 PM
