02 496 ho leak in closed water sysytem? >
Old 09-04-2018 | 08:24 PM
26sonic's Avatar
Default 02 496 ho leak in closed water sysytem?
I have a 02 31 sonic with twin 496 ho engines. Ikeep finding water in the bilge after using boat for the day and letting it sit over nite. I have ruled out any leaks from out side of boat because it has new bellows etc. . if I suck out any water in bilge with shop vacuum and not run engines the bilge is bone dry the next day. but if I run the engines for half hr or so and look in bilge there is no sign of a obvious leak? if I come down the next day and check the bilge will have 1-2 gallons of water? I can run this experiment over and over with same results any ideas where this leak could be coming from in the closed water system or is it something else?
26sonic is offline
