St. Petersburg marinas
Old 09-05-2018 | 08:20 PM
Default St. Petersburg marinas
Hi guys,
Im looking for advise and recommendations for marinas in St. Petersburg or maybe Tampa. I’m moving down from the NE. Where do you keeps your boats? I’m thinking I’d like to keep it on a covered lift where I’d have 24 hour access to it.
Thanks in advance.
Cujo336 is offline
Old 09-05-2018 | 08:26 PM
Originally Posted by Cujo336
Hi guys,
Thanks in advance.
Never seen a marina with covered lifts in Florida.......
Jupiter Sunsation is offline
Old 09-05-2018 | 08:54 PM
I found this one.
Boat Storage | O'Neill's Marina
Cujo336 is offline
Old 09-06-2018 | 10:06 AM
That will more than likely we your only option at all.
Covered lifts and 24 access is VERY rare in this area and shocked you even found that one.
Nate5.0 is offline
Old 09-06-2018 | 08:47 PM
Home Port Marina in Ozona has a few covered slips with lifts. Only about 10 lifts with maybe four being covered.
Powerquest230 is offline
Old 09-06-2018 | 08:50 PM
maximo marina in st pete has just built all new covered slips with a good number of brand new lifts
other than that there are not a lot of options for covered lifts with slips
I think the guy told me the covered lifts are going to run about $750 month
obrien is offline
Old 09-07-2018 | 07:31 AM
That was the same number I heard too, my buddy might move his boat there from Tierra Verde Marina. I am sure they will go quick once completed.
Nate5.0 is offline
Old 09-07-2018 | 07:44 AM
Hi guys,
Thanks in advance.
O’Neil’s has them. It’s kind of small and fishy though.
there are some boat houses under condos on the icw near undertow. Otherwise it’s not a typical Florida style marina.
hogie roll is offline
Old 09-07-2018 | 07:46 AM
mix up
Old 09-08-2018 | 08:43 AM
As already been said, the covered lifts are fairly uncommon down here. We work on boats at a lot of marinas around here and there's everything from very good to very bad. Not saying they're all bad, but after having seen the things we see it would make me nervous to always leave my boat in the care of some of the marina's around here. If you're set on covered it's going to be a much harder hunt but there are always private boat lifts for rent.
luke81 is offline
