distributor rotor not turning 525sc
525sc motors. Roughly 100 hours
Running 4000 rpm last weekend port motor shut down would not start up again. Trailer ed it home.
Tonight turned it over and saw all the rockers moving. Pulled distributor and roll pin is still in tact.
Turned it over while looking down the distributor hole and could not see the cam gear moving.
What am I looking at here? broken cam?
thanks in advance
thanks in advance
Sounds like it,
Crane had a bad large batch of hyd roller cams years back that did this, but I have not heard of a flat tappet cam (525SC had hyd fat tappets) doing this, but I guess anything is possible.
If the cam is rolling and cycling rockers but the cam gear isn't moving....only one thing that can be...bad cam....its possible I guess if the cam gear is pressed on that it could have came loose and is slipping...however regardless the cam needs to come out IMO
Im glad you got it sorted out!
Come on summer!!
