RHS Aluminum Cylinder Heads >
Old 09-05-2018 | 10:17 PM
Default RHS Aluminum Cylinder Heads
For Sale: RHS Aluminum Cylinder Heads removed from a 500 HP Mercury Marine Engine. Heads have less than 30 hours. I replaced these with the stock cast iron heads to accommodate new Gil Exhaust manifolds. $1,000 firm. Contact me at (563)590-3233, Tom, Dubuque, Iowa.
tomswift is offline
Old 09-05-2018 | 10:27 PM
This is for a set of Heads for one engine. Thx Tom
tomswift is offline
Old 09-06-2018 | 02:18 PM
Do you have 1 or 2 sets?
Part # ?
lucky cat is offline
Old 09-09-2018 | 01:36 PM
I have 1 set. I will list the part number that’s on the heads
tomswift is offline
Old 09-10-2018 | 07:18 PM
Default Part Numbers on heads
The part number on the end of the heads is 11301. There is also the following numbers near the valve springs: 606750A And M15
tomswift is offline
Old 09-10-2018 | 07:20 PM
tomswift is offline
Old 09-11-2018 | 08:10 AM
The part number identifies the heads as cast iron and not aluminum.
tomswift is offline
Old 09-12-2018 | 07:58 PM
Default Price Reduced
$900.00 for the set
tomswift is offline
Old 09-14-2018 | 11:23 AM
Those are 320cc versions . Too bad. With a little work they smoke the stock gm heads. I have a buddy running those with GIL manifolds
MILD THUNDER is offline
Old 09-18-2018 | 05:48 PM
Reduced $800 for the set
tomswift is offline
