Need Throttle and Shift Lever >
Old 10-26-2002 | 07:26 PM
Mark in So. MD's Avatar
Default Need Throttle and Shift Lever
My friend,not on the board, is redoing an old boat and he would like to put on the standard Kiekhaefer white throttle and shift lever with power trim(single engine).
I did a search on Doller and Bam for Throttle and Shift Levers and also for Remote Controls(i heard they were called this too) but I could not come up with anything. I went to Marine Machine's website and found them but not prices, he probably doesnt need those nice ones anyway.
Can anyone point me in the right direction or tell me what I did wrong on those sites.
Mark in So. MD is offline
Old 10-26-2002 | 07:41 PM
glassdave's Avatar
Neno the mind boggler
try eddie marine there site is much easier to get around on but they are the pricey shiftres. i have seen a few sets on ebay and the classifieds here. or post in parts wanted .
oh an alot of times they are listed under "controls" when searching
glassdave is offline
Old 10-26-2002 | 07:46 PM
glassdave's Avatar
oops . .never mind . .i see you said controls up there too . . good luck
Old 10-26-2002 | 08:41 PM
timucin's Avatar
gafrig
mm
hope this helps
timucin is offline
Old 10-26-2002 | 09:12 PM
Thanks all.
The reason why he is looking is because the one he has feel like it has got sand in it or like you are running it through sandpaper. It works, just kinda stractchy and rough.
I would imagine he needs a new one but is there anyway to fix that.
Old 10-26-2002 | 09:21 PM
Ted G's Avatar
If it is like the Gaffrigs it can be disassembled, cleaned, and greased. Mine worked like a million after I did it. While he's at it he could repaint too.
www.cbpba.com
Ted G is offline
timucin's Avatar
yes of course;
most of the units are rebuildable; just remove the parts (be careful when aparting th parts there may be seals ,small detail pars etc) ,clean them,use some oils etc (wd40) if needed . and you are done..
good luck
ps: when you apart and cleaned it , dont leave it to next day; rebuild it on the same day....you may loose some parts like cable ends.. .( have an experience)
timucin is offline
Old 10-28-2002 | 11:01 AM
Check with Puder here on the board, he had one that wouldn't fit my dash.
Shah Mat is offline
Kokopelli
13
08-10-2012 05:25 PM
Fortius
08-17-2008 03:15 AM
still smoking
05-29-2007 05:04 PM
SCARABSPORT
12-22-2005 08:33 AM
Qball
3
09-21-2003 08:15 PM
