Engine flooding issue >
Old 09-15-2018 | 06:49 AM
Default Engine flooding issue
I have a 1999 502 efi gen 6 with cool fuel. Engine will fire right up when cold but after I run it under load and shut it off I need to open the throttle up to get it to start. It’s now gotten to the point that I have to go WOT to get it to start. Any help would be greatly appreciated.
Never E Nuff is offline
Old 09-15-2018 | 06:58 AM
have a scanner put on it and see if a sensor is out of whack.or pull the injectors and have them tested
sutphen 30 is online now
Old 09-15-2018 | 07:13 AM
Injectors were rebuilt and tested this spring.
Old 09-16-2018 | 11:51 AM
Any chance you are having fuel bleed into the manifold and flooding the motor? Typically advancing the throttle on an EFI motor will enter the 'flood clear mode' which will shut down the injectors allowing air to clear out the excess fuel. Sounds like this is your problem. I'm not really familiar with the later cool fuel systems but do know that previous VST systems had several issues which would cause flooding when certain inner diaphragms of the VST would deteriorate.
Trash is offline
Old 09-16-2018 | 12:01 PM
BUP
he has a gen 2 cool fuel and clear flood mode still applies here. I would do a fuel pressure check and make sure FPR is good and its related set up.
Also check MAP readings - A bad MAP or out of readings can cause rich conditions
BUP is offline
