Whats a 377 scorpion? A destroked oversquare 400 sbc? What can be done to get more hp >
Old 10-02-2018 | 09:50 PM
Default Whats a 377 scorpion? A destroked oversquare 400 sbc? What can be done to get more hp
Was wondering what a 377 merc scorpion is made up of parts wise and what can be done to get more hp out of one. Thx for any info, Rm
iliveonanisland is offline
Old 10-02-2018 | 10:54 PM
SB
Pretty sure it;s 350 block with a 3.75 stroke crank and standard 4.00" bore pistons.
SB is online now
Old 10-03-2018 | 12:03 AM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
A 377 is a 383 waiting to happen .
the deep is offline
Old 10-03-2018 | 12:09 AM
3.75 x 4.00 is a 383. Or 388. .030 over.
Yhe dirt track guys take a 4.125 bore 400sbc and Run a 350 3.5” stroke crank and run a long rod.
Is the 377 cubic inches or hp?
if it’s 3.75 stroke it must use the pos 305 block which can’t be bored to 383.
Old 10-03-2018 | 12:15 AM
it’s 377 hp it is a weak azz 383. More compression better heads and roller cam and valve train would wake it up.
Old 10-03-2018 | 12:17 AM
Any one sell a blower kit to bump them up to around 500 ponies ?
Old 10-03-2018 | 12:30 AM
SB
Found this
Just came upstairs from working on my sled.i may have a sickness. LOL. Goodnight.
377 cu in Scorpion Specs?
SB is online now
Old 10-03-2018 | 12:34 AM
Found this
Thanks, so at 4.030 it’s a 383. And 388 @ .060
Old 10-03-2018 | 05:11 PM
Don't believe I'd bore a 377 to 383...
Not for the money & work it takes & so little gain...
MR.HAPPY is offline
Old 10-03-2018 | 08:50 PM
It’s a low hour motor but weak af. If i buy it I’ll measure the bores as I will put in forged higher compression pistons, good rods with arp bolts balance the rotating Assm roller cam roller valve train and stud girdle some alum cylinder heads to get the heat out so I can run more compression.
