What performance lowers bolt on a bravo & at what Hp will a bravo live on a 21
wondering what performance lowers are out there that bolt on a bravo and what kind of Hp will a bravo live at on a smaller boat like a 21? Thx for any info, rm
what does a lower like that sell for approximately? Thx for the info, Rm
A stock XR/XZ lower will hold as much power that you’ll be able to effectively utilize in a 21’ boat, and the’ll go as fast as you’ll want to go in a 21’ boat
The main benefit of installing a new lower is IF your prop is TOO low. The shorter lower will raise the prop shaft height and cause less drag and more speed.
I am running an IMCO -3 lower.
The upper is the weak point in a Bravo drive.
