How fast can you tow a Sea-Doo >
Old 10-04-2018 | 03:49 PM
Default How fast can you tow a Sea-Doo
I know this sounds crazy but this is a serious question, can I tow a Sea-Doo 40-45 mph?
GLENAMY 242SS is offline
Old 10-04-2018 | 04:07 PM
you need dual rear outdrives to tow it any faster.....Just be carefull you dont exceed the cleat rating.
phragle is offline
I have towed mine several times at 35 mph. I do have a ball valve installed on the hose when doing so. Have a 100 foot of 3/4 double brad to get it behind the wake
AllDodge is offline
Old 10-04-2018 | 09:55 PM
I towed an 18' Hobie Cat at 50 MPH behind the Donzi. Does that count?
wwahl is offline
Old 10-04-2018 | 10:32 PM
Sure you can
should you? I’ve done it but it probably wasn’t a good idea in retrospect
sailtexas186548 is offline
Old 10-04-2018 | 10:42 PM
Originally Posted by sailtexas186548
Sure you can
Most things that are fun, aren't.....
phragle is offline
Old 10-04-2018 | 11:00 PM
seafordguy's Avatar
Both my newer SeaDoos have had stern warnings that you had to pinch off the water lines in order to tow them. I'd do some research. I assume the danger is sucking water into the exhaust collector and then back into the engine
seafordguy is offline
Old 10-05-2018 | 06:07 AM
I know a guy that did and didn't pinch off the water lines and filled the hole block up with water.
1989mach1 is offline
Old 10-05-2018 | 06:50 AM
t500hps's Avatar
21 and 42 footers
Long tow rope, close off water intake, come off plane slowly so the thing doesn't catch up and hit you!
t500hps is offline
Old 10-05-2018 | 04:06 PM
The important thing is can you tie up a boat dock for 45 minutes while you learn to back a trailer down the ramp in rush hour.
Baja Rooster is offline
