in absence of a gantry...
Old 10-08-2018 | 01:22 PM
Default in absence of a gantry...
3 seasons...15 hours of run time, maybe...4 engines built...one runs...
Pete35Fountain is offline
Old 10-08-2018 | 01:38 PM
The motor was pulled with the drive installed?
AllDodge is offline
Old 10-08-2018 | 01:40 PM
no...just pulled starboard engine,,,drive is removed
Old 10-08-2018 | 01:53 PM
Yep, one of those Forrest for the trees things. I scrolled back n forth across those pics at least 3 times and missed it each time.
Do like the motor hook, have used similar before
AllDodge is offline
Old 10-08-2018 | 06:26 PM
What’s going on with the builds? Why won’t they stay running?
Crude Intentions is offline
Old 10-08-2018 | 06:30 PM
first engine broke a cam shaft into 3 pieces. 15 minutes old (fresh build port engine) second engine took out 4 lobes on the cam shaft that then took out the main and fried the crank. (fresh build starboard) got 6 hours out of this 1
the rebuild starboard spun a main again. don't know why yet, but I have a few guesses. Got 7 hours out of this 1 New machine shop is involved now.
Old 10-08-2018 | 07:10 PM
jeff32's Avatar
I would definatly change something in your recipe! New machine shop is a good place to start with! Good ( or better) luck next time!
jeff32 is offline
Old 10-08-2018 | 07:47 PM
B38
I bet it was comp cams. Garbage!!!!!
B38 is offline
Old 10-08-2018 | 08:02 PM
2 motors ate up the cams? Seems rather odd. Same assembler each time?
apex svt is offline
Old 10-09-2018 | 02:21 AM
yes
