Prop trade? >
Prop trade?
Prop trade?
Old 10-09-2018 | 09:45 PM
Default Prop trade?
Anyone got a 28-30p RH they may wanna trade for a 34p bravo?
Kingwebby11 is offline
Old 01-08-2019 | 07:20 PM
Sounds interesting, I have a Bravo 1 28P RH that's been labbed by BBlades. I run a Velocity 280 and the lab work killed the prop for my boat, too much stern lift. Is your prop stock?
ThisIsLivin is offline
Old 01-08-2019 | 07:37 PM
Yes it’s all stock. In really good condition, No knicks!
Old 01-23-2019 | 11:14 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Let's adjust the recipe. Simple. There shouldn't have been a stern lift change with a standard Lab. The geometry of the propeller would be the same. We can build quite a bit of bow lift into the Bravo 1 family.
The prop in the picture above looks to have a satin not stock high polish finish as well as some potential cup removed. However, photos can be deceiving.
Brett
[email protected]
bbladesprops is offline
Old 01-24-2019 | 07:09 AM
The prop in the photo is stock as stated. My prop was labbed with some pitch added which changed the geometry so much it's now unusable on a Velocity hull. The chine walk becomes almost violent at only 65 with even the slightest amount of trim. I used to run 85 before it started.
