Exhaust questions >
Exhaust questions
Exhaust questions
Old 10-11-2018 | 09:16 PM
Default Exhaust questions
don’t know what to do I’m a boater on a budget, it took me 3 years to save the cash for the boat I wanted. Knowing that boating is not cheap I’ve been saving money for 3 more years knowing my motors would have to be rebuilt at some point, and that some point is now (700 hrs and a pair of stock 454 mags). I have a time set with my engine builder to build me some 496’s, Ive been looking for exhaust and good lord that’s gonna cost me. What’s everyone take can i get away with stock should I buy EMI, stainless marine, imco? I’ve been reading on here about revolution marine exhaust but can’t find it anywhere any suggestions would be great
Njm1313 is offline
Old 10-11-2018 | 10:01 PM
Well at least you don't have a boat payment. That's a good thing. What kind of power you looking at building 550-600? Being on a budget I'd look at some Stainless marine's or Gil's in the swap shop. There always in there. Just make sure there pressure checked and preferably fresh water. There's a lot of threads on hear in regards to exhaust. Do a search when you can.
getrdunn is offline
Old 10-11-2018 | 10:12 PM
There's 2 sets of Hardin marine Stainless headers a page back in the swap shop now. 3k for both sets. Just an FYI.
40fasthawk has them. Otherwise check with sick stinger.
getrdunn is offline
Old 10-12-2018 | 12:41 AM
Revolution Marine has been out of business for several years.
You cannot use stock exhaust with any significant cam upgrade.
You will need long risers/tail pipes that don't mix water until very close to the transom for any decent cam..
If your builder is a MARINE engine builder, then he should know what exhaust you need.
Griff is offline
Old 10-12-2018 | 09:14 AM
Exhaust is the worst part of performance boating. Ungodly expensive and can ruin an engine quickly. Also depending on build runner length matters for true power. Gils/SM work but you will give up power on an NA setup. Longer runner headers like cmi sweeper would be the best but they are 6k+ a set
Crude Intentions is offline
Old 10-12-2018 | 01:57 PM
Runner length without a doubt is NA's best friend. 2,900 set at diamond perf.
getrdunn is offline
Old 10-12-2018 | 02:14 PM
Other thing you should check is your center to center dimension. Not sure what boat your have but that can limit your options as well. I had a 32' with only 32 5/8". (Not very common). Etops with aftermarket dart heads I had about a 1/16th" btwn the two inner. Lightening builds a header for tight centers but once again not exactly what I would consider if on a budget.
getrdunn is offline
