496 HO differentiating aluminum from iron manifolds >
Old 10-21-2018 | 05:04 AM
Default 496 HO differentiating aluminum from iron manifolds
Had 2-foot (or rather, 5-foot)-itis and upgraded to a 96 Powerquest 34 Vyper recently that had spent its entire life on a freshwater lake. Boat was originally equipped with twin 454s, but was repowered in 2003 with 496 HOs. My understanding is that in 03, Merc was putting aluminum exhaust manifolds on these engines. Now that the boat will be used exclusively in salt, that is obviously unacceptable for any length of time. Looking at the manifolds and risers currently equipped, they appear outwardly to be in excellent shape. There are no external signs of corrosion whatsoever around any joints or gaskets. The boat shows pretty meticulous maintenance, but the previous owner of 3 years did not replace the manifolds and does not know if they were ever done. Is there a way to tell by looking at the exterior of the manifolds whether or not they are the newer cast iron variety?
traumamed is offline
Old 10-21-2018 | 07:14 AM
Use a magnet, it will be attracted to iron but not aluminum
AllDodge is offline
Old 10-21-2018 | 10:20 AM
Cast iron models will have core plugs on the exhaust port side. Aluminum models do not.
Ryan00TJ is offline
Old 10-21-2018 | 01:34 PM
BUP
that is correct about the core plugs. there was 4 versions of exhaust manifolds for the 496 -- from 2001 thru 2010. Up to late 2005 - those 2 different versions where Aluminum. The first alum gens were 2 piece with water rails
BUP is offline
Old 10-22-2018 | 04:36 AM
Oops, someone forgot his freshman physics. Thanks for reminding me lol.
Thank you all for the responses. If I have the water rail version, I will need a conversion kit as well, correct? I wasn't paying attention to whether or not I had the water rail, but I will have to take a look at that as well. I will probably get around to taking a harder look in the next day or two.
Old 10-23-2018 | 01:22 AM
I've been running aluminum manifolds in brackish water for decades. I garden hose flush after use but nothing else.
f_inscreenname is offline
Old 10-23-2018 | 12:29 PM
Nearly all aftermarket performance exhaust manifolds are aluminum.
Griff is offline
