540 BBC running poorly >
Old 10-21-2018 | 05:40 PM
Default 540 BBC running poorly
1991 Cigarette 35 Cafe Racer. Twin 540s built by White in TN. 34 hours since built.
I pulled the motors in August in order to replace both transom assemblies.
Everything is reassembled now. Motors not running well. The motors both backfire through the carburetor if base timing isn't well above 25 degrees, which is way too high.
I pulled all the plugs today. Most look ok, some are white and look almost unused but many are dark, some sooty, and some wet. It seems like they should all look similar, but they don't.
I will attach pics of the plugs shortly.
ancho is offline
Old 10-21-2018 | 05:54 PM
ancho is offline
Old 10-21-2018 | 05:56 PM
One more.
ancho is offline
Old 10-21-2018 | 05:57 PM
SB
How much dust got in your carbs or dist cap ?
SB is offline
ancho is offline
Old 10-21-2018 | 05:58 PM
Originally Posted by SB
How much dust got in your carbs ?
Good question. Could have been a lot. They were on my garage floor for 2 months.
ancho is offline
Old 10-21-2018 | 06:31 PM
what ignition system?
compedgemarine is offline
Old 10-21-2018 | 07:23 PM
Tinkerer's Avatar
How old is the fuel in the tanks?
Is this last years gas or was new gas put in and the boat run this summer?
Tinkerer is offline
Old 10-21-2018 | 07:25 PM
Tinkerer's Avatar
Both engines have the same problem so it has to be something common to both. Fuel...
Tinkerer is offline
Old 10-21-2018 | 08:33 PM
MSD distributors and marine 6m-2L boxes. Mallory coils.
ancho is offline
