Dimple rods
Old 10-22-2018 | 08:46 PM
Default Dimple rods
Does anybody know where i can get a 502 conectting rod. The “dimple rod”. I had a spun bearing the the rod is kinda messed up. Need to replace it.
chopperkell is offline
Old 10-23-2018 | 05:59 AM
GM dealer
ezstriper is offline
Old 10-23-2018 | 06:06 AM
call the local machine shops,,they should have 1or 2 they can let go.
sutphen 30 is offline
Old 10-23-2018 | 06:27 AM
F-2 Speedy's Avatar
Call Ron Sporl he's got some laying around..........Sporl Marine
F-2 Speedy is offline
Old 10-23-2018 | 08:30 AM
perfect!! thank you for the info..
Old 10-23-2018 | 09:39 AM
where are you located?
mike tkach is offline
Old 10-23-2018 | 10:44 AM
Im located in Washington state. Belfair. Its a little town south of seattle.
Old 10-23-2018 | 10:59 AM
I know you got at least a few dozen laying around...........
payuppsucker is offline
Old 10-23-2018 | 11:42 AM
Not worth fooling with a used one. It should probably be magnafluxed and resized and by the time you do that the new ones from GM end up about the same price. Pretty sure the part number is 19170198 Summit has them in stock for $138
BillK is offline
Old 10-23-2018 | 12:20 PM
thank you. I looked up that part number and it is a big block chevy rod but doesnt look like its a “dimple rod”. Mine have a little bump towards the too which i found out means its a dimple rod. Is that going to matter? Using one disfferent rod?
