Procharger imfo >
Procharger imfo
Procharger imfo
Old 10-29-2018 | 05:36 PM
tripps's Avatar
Default Procharger imfo
Got a procharger for my 454 has 9.5 to one comp any tricks to this it's in a 23 Daytona cat w a bravo w 1.5 gear ratio any cam reccomendantions? Have a 550 lift high duration cam looks like it's gonna be a project i have dry headers that big charger ,I have cmi's also any imf o will be helpful cam is hydraulic !!!boat goes 80 now
tripps is offline
Old 10-29-2018 | 05:55 PM
GPM
What model Pro Charger
GPM is offline
Old 10-30-2018 | 12:19 AM
Most likely will only be able run 4lbs of boost at most with a 9.5 comp ratio using pump fuel.
Griff is offline
Old 10-30-2018 | 06:56 AM
tripps's Avatar
Default Procharger
It's a p600 was using dry headers now I c they don't fit it's a 12 rib pulley set but charger i got is 8 hopefully they have pulleys
tripps is offline
Old 10-30-2018 | 05:49 PM
GPM
Are you going to run an intercooler ?
GPM is offline
Old 10-31-2018 | 12:24 PM
Whats high duration? 220, 230, 240, 250, ? Hyd or solid? Flat tappet or roller? What heads? What exhaust?
MILD THUNDER is offline
Old 12-16-2018 | 09:34 AM
tripps's Avatar
Default Imfo
Hyd flat tappet 312 324 duration advertised 188 gm iron heads dry headers and some nice stellings
tripps is offline
