Like new Stern Powr outdrive for sale >
Old 10-31-2018 | 04:37 PM
Default Like new Stern Powr outdrive for sale
I have a Stern Powr outdrive about as perfect as you can find on eBay.just search for Stern Powr
Warship2k15 is offline
Old 02-05-2020 | 09:08 PM
Default Stern-power
Looking for any info or parts for a stern-power 105 out-drive. any leads ? contact me at [email protected]
sbcokeman is offline
Old 02-06-2020 | 05:37 PM
What kind of parts are you looking for
JoHnSoN is offline
Old 02-06-2020 | 06:00 PM
looking for a manual for the 105 at best a prop shaft for that model
Old 03-18-2020 | 05:13 PM
Default Stern Powr parts
I have some 105 parts. What are u looking for exactly???
Blownbillybob is offline
Old 03-18-2020 | 07:06 PM
a hub or a prop, do they come with separate hubs or are they built into the prop: ?
Old 03-19-2020 | 11:55 AM
Default Shaft
Depends ?? most OEM performance props were threw exh type but were solid no rubber dampener and were cleaver type blades
OEM stock were BIG round ear exh over his rubber dampener
and then there were the racing cleaver #3A style
there was a guy making hub adapters for regular merc props! But not no more!!
Old 03-19-2020 | 11:57 AM
Default Prop
Do U know what size prop ur looking for ??
Old 03-20-2020 | 09:29 AM
was looking for about a 19 or 20 pitch, i have got a friend that is a machinist and we are making a hub that we can use with the bravo 1 series. starting with a volvo penta hub 17 spline and fitting it in a solid bravo hub. that way we can switch props to find right one. thank you fro your reply: Mitch
Old 03-21-2020 | 07:27 AM
Default Hub
The Volvo Penta 17 spline does not fit the stem Powr 17 spline different OD and depending on ur prop shaft u have to shorten the length of the spline in the hub!!!! Which gets pretty short
allready been done that??????
what series 105 do U have. 100 - 1000
theres different spline lengths depending on model?
i do have a hub adapter but not ready to let it go !!!
