Lots of parts
Old 11-05-2018 | 01:54 AM
Default Lots of parts
Cleaning shop. MAKE OFFERS. Please feel free to text me at 480-336-0880. Buyer pays shipping. May consider trades for ls parts, engines etc. Located in Arizona.
(2) B&M 250 Blowers Rec Port with extra pullies - 80 Hours Since Rebuild $4k pair or 2100 each
(2) QuickFuel 1050 Dominator QFX 2 Circuit Carbs - Boost Referenced - 30 Hours 650 each
(2) 741 Crane Camshafts Gen 6 30 Hours 300 each
(2) NEW Custom Straub Solid Blower Cams - Capable of 850 HP at 6psi boost with proper build. Set up for 489-496 max rpm 5700. Specs upon request 425 each
(2) NEW PAC valve spring sets 73367k1 1.550" offers?
32 Crane Gold Rockers - New style - 30 Hours $275 per set
(2) Pairs Enginequest 320 Cylinder heads with Ferrea Superalloy Valves and 99896 Crane Valve Springs, Studs, etc - 30 Hours 1700 each set
(2) Comp Cams XM284hr Casmshafts gen 6 - 60 Hours 200 each
(2) New Melling Select Oil Pumps High Volume
2 Pairs 2 piece valve covers - Not the crap KE- Very good quality $400 per set
(2) Melling billet timing sets - 30 Hours 60 each
1 502 mag camshaft - New $50
32 Morel Solid Roller Lifters - Dyno time 450 per set
(16) Scat Forged I Beam Rods - 80 Hours $200 per set
(16) Icon Forged Pistons 4.280 6.385 Rods 489 - 80 Hours $275 per set
(2) 8 quart oil pans used $125 each
(2) Gil manifold Sets 350 each
1 pair stelling green headers- been repair and pass pressure test $1400
(3) pair stelling green headers - Need to be repaired - All leaking areas marked and verified with borescope $500 per set
(2) MSD rtr billet distributors - 30 Hours 200 each
(2) Proform 4150 Square port intake manifolds - Victor jr copy - Dyno time 100 each
(2) Scat Dampers - 80 Hours
(2) Flywheel - 80 Hours $75 each
(2) gen 6 timing covers
(1) NEW Scat Cast 4.25 Stroke Crankshaft Gen 6
(2) Sea Water Pumps w/ Brackets- Cast housing style. Not Cheap Plastic
(2) Mallory Marine Starters - 30 Hours
(2) NEW King HP std crank bearing set
(2) NEW King HP stdx crank bearing set
(2) New King HP std rod bearing set
(2) NEW King HP stdx rod bearing set
1 NEW King XP STD Crank Bearing set
1 New King XP STDX Crank Bearing Set
Several Manley Severe Duty Valves Different Sizes and Lengths
Several Chromoly Pushrods Sizes
mggdoors is offline
Old 11-05-2018 | 04:20 AM
$500 for the 741 cams
$150 for the 8quart oil pans if they are gen 5/6
$50 for the timing covers
and do you have pics of the 2 pcs valve covers I may want them
dennis r is offline
Old 11-05-2018 | 09:25 AM
In Line for Crane Cam also.
KRAUSMOTORSPORTS is offline
Old 11-05-2018 | 09:57 AM
mggdoors is offline
Old 11-05-2018 | 10:57 AM
i will pass on the valve covers but want the other things if your ok with the price
dennis r is offline
Old 11-05-2018 | 12:14 PM
Part number on the morel solid roller lifters?
Thanks.
SS496 is offline
Old 11-05-2018 | 12:50 PM
Morel 4809. Oil feed roller with link bars
mggdoors is offline
Old 11-05-2018 | 02:14 PM
Easiest way to reach me is via text message
mggdoors is offline
Old 11-05-2018 | 02:32 PM
what is your number your in box is full
dennis r is offline
Old 11-05-2018 | 02:48 PM
F-2 Speedy's Avatar
its underlined in the first post_____________________________
F-2 Speedy is offline
