Heat exchanger for blower motor 1K hp >
Old 11-09-2018 | 04:42 PM
Default Heat exchanger for blower motor 1K hp
Hi, We are building a 532 inch long rod blower engine for racing, I need a heat exchanger for closed water cooling, Has anyone got a good one or can recommend which product to use and what size we would need....Just cant bring myself to flow sea water through the engine
I have an EGR cooler from a Detroit DD15 but its a little big i think, although would certainly do the job and built very well..but a bit ungainly...
Jas
ecuchips is offline
Old 11-09-2018 | 07:46 PM
Following...
bigfarmer is offline
Old 11-09-2018 | 08:39 PM
Rookie's Avatar
Call Mr.Cool for a custom system. Real helpful.
MRM-5322 Off-Engine High Performance 700-900 HP
Rookie is offline
Old 11-10-2018 | 10:06 AM
I agree. Good people there.
Ryan00TJ is offline
Old 11-30-2018 | 03:06 AM
Thanks guys, But we are going to use an egr cooler from a DD15, good size and really well built. I will post some pictures if it done tomorrow
ecuchips is offline
Old 11-30-2018 | 05:07 AM
Anyone have some pictures of a "off engine" set up. ? that could get the bilge kinda bulky with hoses ? , especially for a full FWC system .
open87 is offline
Old 11-30-2018 | 06:56 AM
Are you running a inner cooler also? If yes will it be raw or closed? I assume if closed some type of electric pump to run the water through?
Wildman_grafix is offline
Old 11-30-2018 | 01:04 PM
I will post some pictures once I have it installed.. Jas
ecuchips is offline
Old 11-30-2018 | 01:10 PM
I just can't bring myself to pump sea water across the intake manifold in an offshore boat so we are going to run water injection with a little methonal added, we only need 6 pounds of boost to make the power we need so the water will keep the intake temps nice and low.. Jas
ecuchips is offline
Old 12-01-2018 | 12:58 AM
ecuchips is offline
