Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Opinions on when to renovate and when to scrap >
Old 11-10-2018 | 02:05 PM
Default Opinions on when to renovate and when to scrap
Hi, I bought a 1988 wellcraft Nova 23XL last spring With the 454 330hp and bravo 1. The boat was to be a usable project boat that I would have improvements and upgrades done each winter during storage. This boat gave our family a fantastic summer and we truly love the style and character of this old boat. Thing is...we now have had it checked over by a fiberglass guy for some repairs his opinions were shocking. According to his survey and humidity tests. The bottom hull is ok internally however the gelcoat is full of hair line cracks and has some edges chipped away. This needs to be grinded down to the fiberglass and redone completely all which is at/below the waterline $5000 .
Next , the top fiberglass over the cabin is very badly cracked and has absorbed some water. He said it is the worst part of the boat and needs to be cut out and rebuilt. $8000. After all that work is done the paint job will be totally wrecked so a wrap will run $5000.
The boat cost and is also evaluated at $13 000.
to bring up the hull to good but probably not even excellent condition it will cost us $18 000 more. The mechanics are ok but in the next few years will obviously need attention aside from the regular maintenance
So, if the options are basically accept the financial burden and start rebuilding this boat
OR
sell it at a slight loss and hopefully find a similar boat with less repairs ( or perhaps get stuck in a equally difficult situation with different old boat)
OR
Do only essential bodywork such as redo below the waterline and drive it as-is until it dies...
What would you do?
Jase is offline
Old 11-10-2018 | 02:49 PM
Its an 88 welcraft...the stress cracks on the bottom are more than likely from the stringers being toast and the transom may not be far behind.... They are all over for under 10 grand.
phragle is offline
Old 11-10-2018 | 03:21 PM
Thanks for the response,In fact I'm in Canada. There are no Nova's around my area except mine and another guy has a spyder. So it's not a question of replacing parts with parts from scrap yards or other boat hulls hidden away in a garage or even switching up for a better Nova. It's really boat building guys doing their best to repair the hull. According to two hull survey guys with their meters ( no idea how accurate that can be, and tapping the hull all over). Aside from the surface the inside of the hull /stringers are dry. The assumption for the cracks is the last owner trailering the boat constantly and cranking the heck out of it. But all this is talk, no idea on what is 100% going on. There are 2 huge stringers supporting the engine. They tested dry with the meter.
Our dilemma is pouring money into this hull (boat) and crossing fingers to get a quality 8 years from it. If we do the work and the thing falls apart in 3 years I will probably literally cry...
Jase is offline
Old 11-10-2018 | 05:29 PM
If you have the work done by a GOOD glass guy, it should be good for another 30 years, have it done by a bad glass guy and you will get 3 weekends out of it. Some piks would go a long way to seeing whats really up.. small spider web stress cracks are common and usually cosmetic... ...
I have seen a boat with the ENTIRE bottom cut off just above the chine, and a whole new bottom put on it... anything is possible, fiberglass is just paper mache' for big kids....
phragle is offline
Old 11-10-2018 | 07:08 PM
Was your purchase price a relatively great deal? Are the issues with the bottom a significant safety issue in the near future? My intitial thought is to run it until you can’t while shopping for a fresher boat with the money you could’ve poured into this thing. Initial estimates are usually half of the total bill in the end.
Baja Rooster is offline
Old 11-10-2018 | 08:01 PM
rak rua's Avatar
All good advice above.
Unless you want a DIY project or the boat is a classic with a history, it's not really worth pouring money into. If your fiberglass guy is confident the boat is structurally sound (I.e. safe and seaworthy) and you're having fun running it, keep going another season or two while keeping your eyes on the market.
Two thing's are for certain, if you do a resto job, it will cost you more than you would anticipate and no matter how good of a job you do, you won't get your money back.
RR
P.S. Don't let the import issues/taxes stop you shopping U.S. boats, just factor in a few extra dollars. My understanding is the used boat market is absolutely huge in the U.S. and there are always good deals to be found.
rak rua is offline
Old 11-11-2018 | 12:43 AM
I would definitely not spend the money to fix it. I would just use it and keep an eye on the issues to make sure they do not develop into safety issues.
Griff is offline
Old 11-11-2018 | 06:54 AM
I would not spend a penny. Buddy similar situation once, some spider cracks n chips, called in a pro, quoted 3500 to grind down and redo gelcoat, would have required stripping all from transom including swim platform drives, gimbal, tabs, exhaust you get the picture,. He decided to take his chances, purchased some chip repair epoxy and liquid spider crack filler from local chandlery and spent a couple hours doing his own repair / patches. came out acceptable, minor touch ups every winter, 7 years and still going strong, I know because it's stored in my warehouse every winter. Save your money, have fun boating !!
Excess is offline
Old 11-11-2018 | 09:03 AM
It looks to me like the trailer is ill fitting. It’s important that the bunks extend past the transom and fully support it. It also appears that the trailer was made for a boat with less deadrise than yours. The trailer does not look long enough or deep enough. From what I have read, many years ago in Trailer Boats Magazine, you can do serious damage to your boat pulling and storing it on the wrong trailer. I wonder if Jim Barron is still alive?!
liquidlounge is offline
Old 11-12-2018 | 12:16 PM
Don't do anything to it. Enjoy as is. If you want out of it or if you want it to be perfect then sell it and start over. Not worth throwing money at IMO.
TexomaPowerboater is offline
