carb engine harness and 525 sea pumps >
Old 11-11-2018 | 11:31 AM
F-2 Speedy's Avatar
Default carb engine harness and 525 sea pumps
2- like new engine harnesses for carb engine.....150.00 each
2- like new sea pumps with fuel pump mount and bracket, these are over 600.00 new without the housing, I have drilled and tapped these with drain plug....400.00 each
+ shipping on all parts.
Thanks for looking...
F-2 Speedy is offline
Old 11-11-2018 | 01:05 PM
If these were available earlier I probably would’ve grabbed them.
Bump for a solid seller the parts i bought off of F2 literally looked like they came off the dealer shelf.
Baja Rooster is offline
Old 11-12-2018 | 03:52 PM
F-2 Speedy's Avatar
reasonable offers ??
Old 11-13-2018 | 02:01 PM
Veteran: Army
Default wire harness
are they 8 pin or 9 pin ? & do you still have pulleys ? if so my offer still stands
kgz3 is offline
Old 11-13-2018 | 02:24 PM
F-2 Speedy's Avatar
9 pin harnesses .......what was the offer, I have a good memory but short..........I was asking 40 each 80 for the pair
Old 11-13-2018 | 04:37 PM
I'm a buyer for the harnesses at 80 for the pair
regalman4925 is offline
Old 11-14-2018 | 06:44 AM
I will give you $150 for the pair of harness
dennis r is offline
Old 11-14-2018 | 06:51 AM
F-2 Speedy's Avatar
I sent you a pm
Old 11-14-2018 | 08:23 AM
Veteran: Army
i will give you $ 190.00 for the 2 wire harness & the 2 pulleys ph # 309-925-4620 or 309-453-1177 karl
kgz3 is offline
Old 11-14-2018 | 10:12 AM
F-2 Speedy's Avatar
harnesses sold, thank you
300 each for the sea pumps ++++ shipping
