88 33’ Sonic part out
- Twin 540s, 600hp - bow tie blocks, Merlin heads, Comp roller rockers, roller cams, 10qt Gil oil pans, DUI ignition, dominator carbs, dominator arrestors - flywheel to pulley, carb to pan, less than 30 hours $16,000 for pair
- Gil bravo exhaust $1200 each or $2000 for pair
- Bravo 1 1:50 $2000 each
- 28P props $650 pair
- Imco full hydro steering set up $2500
- 280 tabs $1000
- Controls with trim $225
- Livosi gauges $120, these are the 4 on top of the panel.
- Platform $1100
- MSD dristibutor, box & coil with wiring $425 each set
- 1994 CHawk trailer - 6 lug triple axel, 15,000 GVW, with title $3500
- Transom assemblies (Parts only - rings are worn) $250 each
- Hull on trailer - includes bolsters, gauges, controls, indicators, transom assemblies, motor mounts, battery charger, full cuddy (hull is free - only paying for parts) $5500
