Bravo drive line and other parts
All primo stuff here, cleaning out the house and shed
Bravo driveline new bearings installed in carrier and hangar, new input shaft, all mercury parts from and installed by mercury dealer.
All mounting/assembly hardware from mercury most still in original bags, drive shaft needs u joints.
1500.00 plus shipping
Steering resovoir 50.00 plus shipping
Drive oil resovoir 50.00 plush shipping
Thunderbolt 4 ignition 20* 100.00 plus shipping
New 4 inch blower and vent make offer
Mounts and brackets make offer
Wire loom 1/2 3/4 1 1/4 pay shipping
Still have brand new drive indicator (see link)
New unused drive indicator and thru hull.
Bell housing top mount starter pad machined for depth to use with rear offshore plate
Same bellhousing on my 496 using block mounted starter with no clearance issues
Ok steering res is yours i'll send a text
1 1/4, 3/4 looms are 50 feet each, believe the 1/2 to be at least 25 feet left on the roll if not more.
Shrink wrapping the ends stops fraying and looks clean
Post 2 is the driveline, ( bell housing, carrier, hangar, input shaft and driveshaft)
All nuts bolts and washers are in the bag.
I have front and rear pedestal mounts and angles that can be used with the driveline.
They are mercury mounts, it puts all 4 corners of the engine on pedestals for alignment.
My stringers are too wide or else i would have used them and the driveline in my boat
It is a complete driveline, in terms of a hi performance installation
I take it in picture 1 for the reservoirs ----- so which reservoir is still for sale ? the full silver metal one or the clear view one or both ?
In pic 1 -- lower left corner - the 2 silver brackets ( possible aluminum ) with 5 holes in them --- what are they for ? Sorry I can not enlarge the pics for some reason so I am asking these questions.
The stainless steel steering resovoir is sold
The clear resovoir is still available ( it is a drive lube bottle )
couldnt use it on my boat with the 496
The brackets with the 5 holes bolt onto the back of a cylinder head (2 bolt holes )
the other 3 holes are for a filter head.
They are mercury parts and yep they are aluminum.
