500EFI cams in 454 mag?
Old 11-12-2018 | 09:00 AM
Default 500EFI cams in 454 mag?
I have been searching for 731 cams with no luck for my gen 6 454 mag on roids builds. I found some 500EFI cams on the cheap, the specs are close to the crane 731s. Has anyone tried this? results? The engines are carbed, SM exhaust, upgraded oil cooling system. Thanks
168731
Camshaft, Hydraulic Roller Tappet, Advertised Duration 288/298, Lift .587/.610
169621
Camshaft, Hydraulic Roller Tappet, Advertised Duration 292/298, Lift .598/.610
regalman4925 is offline
Old 11-12-2018 | 08:02 PM
Run it.
getrdunn is offline
Old 11-12-2018 | 08:12 PM
enjoy it, check the lifter travel closely, I went with tiebar cranes to be on the safe side the .610 is on the edge for stock dogbones
phragle is offline
Old 11-12-2018 | 10:29 PM
what does ssm exhaust mean.reversion is something to worry about with wet exhaust.
mike tkach is offline
Old 11-12-2018 | 10:42 PM
Lsa on the EFI cam? 112?
Baja Rooster is offline
Old 11-12-2018 | 11:16 PM
You won't see any power difference between them
Griff is offline
Old 11-13-2018 | 07:09 AM
Stainless marine. the pipes are tall and will be dry to the tip
Thanks guys, I grabbed them last night
Old 11-14-2018 | 01:32 PM
I put cams similar to 500 efi's in my 420's. They are andrews cores bought through teague but same specs. They sound great, quite a bit of lift though, you will need good valve train.
TylerBurich is offline
Old 11-14-2018 | 01:57 PM
I put the Comp Cams 525EFI clone (near identical to Crane 741) and they recommended the dog bone lifter setup. I checked with Eddie Young and he said run ‘em and be happy, and I triple checked the set up for clearance and travel and it all looked great. I’ve heard great things about the Comp Cams short travel lifters if you want tie bar lifters, but the cams you got should work with the stock dog bones if you wish. I did need new push rods though.
Old 12-07-2018 | 12:34 PM
I ended up buying the complete heads, lifters and push rods from the same engines the cams came from. the only part of the valve train that was not included were rockers and I have harland sharp rockers already purchased. I may swap springs just to be safe
